주요 콘텐츠로 건너뛰기
TMY V08 Button Circuit Board Replacement
필요한 것
  1. TMY V08 Button Circuit Board Replacement, Top Panel: 1 단계, 이미지 1/3 TMY V08 Button Circuit Board Replacement, Top Panel: 1 단계, 이미지 2/3 TMY V08 Button Circuit Board Replacement, Top Panel: 1 단계, 이미지 3/3
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Button Circuit Board Replacement: 2 단계, 이미지 1/3 TMY V08 Button Circuit Board Replacement: 2 단계, 이미지 2/3 TMY V08 Button Circuit Board Replacement: 2 단계, 이미지 3/3
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Button Circuit Board Replacement, Button Circuit Board: 3 단계, 이미지 1/3 TMY V08 Button Circuit Board Replacement, Button Circuit Board: 3 단계, 이미지 2/3 TMY V08 Button Circuit Board Replacement, Button Circuit Board: 3 단계, 이미지 3/3
    • Remove the four 4.8 mm screws from the button circuit board beneath the top cover using a Phillips #1 screwdriver.
    • Remove the button circuit board.
결론
Joanna Jimenez
회원 가입일: 10/02/23
73 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 6
전체 시간: 55
