주요 콘텐츠로 건너뛰기
TMY V08 Cooling Fan Replacement
필요한 것
  1. TMY V08 Cooling Fan Replacement, Top Panel: 1 단계, 이미지 1/3 TMY V08 Cooling Fan Replacement, Top Panel: 1 단계, 이미지 2/3 TMY V08 Cooling Fan Replacement, Top Panel: 1 단계, 이미지 3/3
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Cooling Fan Replacement: 2 단계, 이미지 1/3 TMY V08 Cooling Fan Replacement: 2 단계, 이미지 2/3 TMY V08 Cooling Fan Replacement: 2 단계, 이미지 3/3
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 1/3 TMY V08 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 2/3 TMY V08 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 3/3
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
  4. TMY V08 Cooling Fan Replacement: 4 단계, 이미지 1/2 TMY V08 Cooling Fan Replacement: 4 단계, 이미지 2/2
    • Rotate the projector counterclockwise 90 degrees.
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
  5. TMY V08 Cooling Fan Replacement: 5 단계, 이미지 1/3 TMY V08 Cooling Fan Replacement: 5 단계, 이미지 2/3 TMY V08 Cooling Fan Replacement: 5 단계, 이미지 3/3
    • Rotate the projector counter clockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
  6. TMY V08 Cooling Fan Replacement: 6 단계, 이미지 1/3 TMY V08 Cooling Fan Replacement: 6 단계, 이미지 2/3 TMY V08 Cooling Fan Replacement: 6 단계, 이미지 3/3
    • Remove the five 7.3 mm screws from the black cover using a Phillips #1 screwdriver.
    • Take off the right black cover, exposing the fan.
  7. TMY V08 Cooling Fan Replacement: 7 단계, 이미지 1/1
    • Firmly grasp and lift up the fan to remove it.
결론
Randolph Bill
회원 가입일: 10/02/23
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 96
