주요 콘텐츠로 건너뛰기
TMY V08 Lens Replacement
필요한 것
  1. TMY V08 Lens Replacement, Top Panel: 1 단계, 이미지 3개 중 1개 TMY V08 Lens Replacement, Top Panel: 1 단계, 이미지 3개 중 2개 TMY V08 Lens Replacement, Top Panel: 1 단계, 이미지 3개 중 3개
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Lens Replacement: 2 단계, 이미지 3개 중 1개 TMY V08 Lens Replacement: 2 단계, 이미지 3개 중 2개 TMY V08 Lens Replacement: 2 단계, 이미지 3개 중 3개
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Lens Replacement, Lens: 3 단계, 이미지 3개 중 1개 TMY V08 Lens Replacement, Lens: 3 단계, 이미지 3개 중 2개 TMY V08 Lens Replacement, Lens: 3 단계, 이미지 3개 중 3개
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
  4. TMY V08 Lens Replacement: 4 단계, 이미지 2개 중 1개 TMY V08 Lens Replacement: 4 단계, 이미지 2개 중 2개
    • Rotate the projector counterclockwise 90 degrees.
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
  5. TMY V08 Lens Replacement: 5 단계, 이미지 3개 중 1개 TMY V08 Lens Replacement: 5 단계, 이미지 3개 중 2개 TMY V08 Lens Replacement: 5 단계, 이미지 3개 중 3개
    • Rotate the projector counter clockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
  6. TMY V08 Lens Replacement: 6 단계, 이미지 2개 중 1개 TMY V08 Lens Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the projector over so the bottom is facing up.
    • Remove the two 13.9 mm screws using a Phillips #1 screwdriver.
  7. TMY V08 Lens Replacement: 7 단계, 이미지 2개 중 1개 TMY V08 Lens Replacement: 7 단계, 이미지 2개 중 2개
    • Flip the projector back over.
    • Remove the fine gauge adjustment, by lifting it out.
  8. TMY V08 Lens Replacement: 8 단계, 이미지 3개 중 1개 TMY V08 Lens Replacement: 8 단계, 이미지 3개 중 2개 TMY V08 Lens Replacement: 8 단계, 이미지 3개 중 3개
    • Grasp the side of the lens.
    • Pull the lens outward away from the hole while pulling upward to remove the lens.
결론
작성자
4다른 기여자 명과 함께
Lesli
회원 가입일: 10/02/23
303 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 52
전체 시간: 1,046
