주요 콘텐츠로 건너뛰기
TMY V08 Speaker Replacement
필요한 것
  1. TMY V08 Speaker Replacement, Top Panel: 1 단계, 이미지 3개 중 1개 TMY V08 Speaker Replacement, Top Panel: 1 단계, 이미지 3개 중 2개 TMY V08 Speaker Replacement, Top Panel: 1 단계, 이미지 3개 중 3개
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Speaker Replacement: 2 단계, 이미지 3개 중 1개 TMY V08 Speaker Replacement: 2 단계, 이미지 3개 중 2개 TMY V08 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 1개 TMY V08 Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 2개 TMY V08 Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 3개
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
  4. TMY V08 Speaker Replacement: 4 단계, 이미지 2개 중 1개 TMY V08 Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Rotate the projector counterclockwise 90 degrees
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
  5. TMY V08 Speaker Replacement: 5 단계, 이미지 3개 중 1개 TMY V08 Speaker Replacement: 5 단계, 이미지 3개 중 2개 TMY V08 Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Rotate the projector counterclockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
  6. TMY V08 Speaker Replacement: 6 단계, 이미지 3개 중 1개 TMY V08 Speaker Replacement: 6 단계, 이미지 3개 중 2개 TMY V08 Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the five 7.3 mm screws from the black cover using a Phillips #1 screwdriver.
    • Take off the right black cover, exposing the speaker.
  7. TMY V08 Speaker Replacement: 7 단계, 이미지 2개 중 1개 TMY V08 Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Grasp the speaker firmly and lift up to remove.
결론
작성자
5다른 기여자 명과 함께
Wesley
회원 가입일: 10/09/23
271 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 18
전체 시간: 202
