주요 콘텐츠로 건너뛰기
TOZO HT2 Main Board Replacement
필요한 것
  1. TOZO HT2 Main Board Replacement, Ear Pad: 1 단계, 이미지 3개 중 1개 TOZO HT2 Main Board Replacement, Ear Pad: 1 단계, 이미지 3개 중 2개 TOZO HT2 Main Board Replacement, Ear Pad: 1 단계, 이미지 3개 중 3개
    • Firmly hold the headphone housing in one hand to hold the device steady and put the other hand on the ear pad you intend to replace.
    • Note: Do not force the ear pad to come off or you risk breaking the tabs that keep the pads in place.
  2. TOZO HT2 Main Board Replacement: 2 단계, 이미지 3개 중 1개 TOZO HT2 Main Board Replacement: 2 단계, 이미지 3개 중 2개 TOZO HT2 Main Board Replacement: 2 단계, 이미지 3개 중 3개
    • Twist the ear cover counterclockwise until it pops off.
    • Repeat for the other ear pad if necessary.
  3. TOZO HT2 Main Board Replacement, Main Board: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove each of the four screws on the speaker cover.
    • Lift the cover off without pulling on the wires inside and set it to the side to access the circuit board.
  4. TOZO HT2 Main Board Replacement: 4 단계, 이미지 2개 중 1개 TOZO HT2 Main Board Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Philips screwdriver to remove the screws that secure the main board.
    • Carefully lift the board out of the headphones, making sure to not pull on and damage the wires inside.
  5. TOZO HT2 Main Board Replacement: 5 단계, 이미지 1개 중 1개
    • Use flush cutters to cut the wires as close as possible to their main board connections.
  6. TOZO HT2 Main Board Replacement: 6 단계, 이미지 1개 중 1개
    • Soldering how to
    • Use this guide to reattach the wires to the circuit board.
    • HANDLE WITH CARE: Soldering Iron becomes VERY Hot (Up to or above 400°C or 800°F).
    • Wear eye protection while soldering and only do so in a well ventilated room and/or with a fume extractor.
    • Remove all possible fire hazards from the surrounding area.
    • Keep all animals and children out of the room.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
4다른 기여자 명과 함께
Raven M
회원 가입일: 08/28/24
614 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 290
