주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tagital T7X Battery Replacement
필요한 것
  1. Tagital T7X Battery Replacement, Case: 1 단계, 이미지 3개 중 1개 Tagital T7X Battery Replacement, Case: 1 단계, 이미지 3개 중 2개 Tagital T7X Battery Replacement, Case: 1 단계, 이미지 3개 중 3개
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Battery Replacement, Battery: 2 단계, 이미지 2개 중 1개 Tagital T7X Battery Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Follow the attached wires to the positive and negative connections.
  3. Tagital T7X Battery Replacement: 3 단계, 이미지 3개 중 1개 Tagital T7X Battery Replacement: 3 단계, 이미지 3개 중 2개 Tagital T7X Battery Replacement: 3 단계, 이미지 3개 중 3개
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the negative wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
    • Repeat this step for the positive wire.
  4. Tagital T7X Battery Replacement: 4 단계, 이미지 3개 중 1개 Tagital T7X Battery Replacement: 4 단계, 이미지 3개 중 2개 Tagital T7X Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
    • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kevin Dennis
회원 가입일: 02/10/16
184 평판
안내서 1개를 작성함
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G1
4 회원들
안내서 12개를 작성함
1가이드 댓글
We're can I get a battery? And I don't think the part should have died in less than a year . The battery lasted less than 6 mos. I bought the tablet for my mom to play cards on and that's it .She doesn't go on line. I put a book on it before I gave it to her and that is it. She doesn't even use it every day . What's the deal?
Melanie Bouy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 45
전체 시간: 1,321
