주요 콘텐츠로 건너뛰기
Tagital T7X Speaker Replacement
필요한 것
  1. Tagital T7X Speaker Replacement, Case: 1 단계, 이미지 1/3 Tagital T7X Speaker Replacement, Case: 1 단계, 이미지 2/3 Tagital T7X Speaker Replacement, Case: 1 단계, 이미지 3/3
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Speaker Replacement, Speaker: 2 단계, 이미지 1/3 Tagital T7X Speaker Replacement, Speaker: 2 단계, 이미지 2/3 Tagital T7X Speaker Replacement, Speaker: 2 단계, 이미지 3/3
    • Remove the ribbon cable on the top left corner of the mother board.
    • Gently lift the black tape up to see the ribbon cable socket.
  3. Tagital T7X Speaker Replacement: 3 단계, 이미지 1/3 Tagital T7X Speaker Replacement: 3 단계, 이미지 2/3 Tagital T7X Speaker Replacement: 3 단계, 이미지 3/3
    • Push both side buttons away from the socket by using a spudger.
  4. Tagital T7X Speaker Replacement: 4 단계, 이미지 1/2 Tagital T7X Speaker Replacement: 4 단계, 이미지 2/2
    • Gently pull the ribbon cable away from the socket.
    • Don't be afraid to use some force for this step.
  5. Tagital T7X Speaker Replacement: 5 단계, 이미지 1/2 Tagital T7X Speaker Replacement: 5 단계, 이미지 2/2
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • Repeat this step for the negative wire.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
  6. Tagital T7X Speaker Replacement: 6 단계, 이미지 1/2 Tagital T7X Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the speaker from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hanlong Chen
회원 가입일: 02/10/16
265 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 204
