소개
Use this guide when the auxiliary port needs to be replaced.
필요한 것
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
이 단계에 사용된 도구:Desoldering Pump$3.99
Remove the solder between the auxiliary port and the motherboard carefully with the desoldering pump.
거의 끝나갑니다!
결론
