주요 콘텐츠로 건너뛰기
Tapwave T2907US Zodiac 2 Shoulder Button Replacement
필요한 것
  1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Pull off the black memory card slot piece with tweezers.
  7. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 8 단계, 이미지 2개 중 1개 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 10 단계, 이미지 1개 중 1개
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  11. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 11 단계, 이미지 3개 중 1개 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 11 단계, 이미지 3개 중 2개 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: 11 단계, 이미지 3개 중 3개
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
  12. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Shoulder Button: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Carefully remove the solder between the shoulder buttons and the motherboard with the soldering sucker.
    • Try to avoid contact between the solder sucker and other components surrounding the shoulder buttons.
    • For more information on desoldering, look at this soldering/desoldering guide.
결론
작성자
5다른 기여자 명과 함께
Daniel Wiseman
회원 가입일: 01/20/12
133 평판
안내서 6개를 작성함
Cal Poly, Team 10-33, Amido Winter 2012 Cal Poly, Team 10-33, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G33
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 943
