주요 콘텐츠로 건너뛰기
Teddy Ruxpin Mouth Replacement
필요한 것
  1. Teddy Ruxpin Mouth Replacement, Battery: 1 단계, 이미지 2개 중 1개 Teddy Ruxpin Mouth Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Mouth Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Mouth Replacement: 3 단계, 이미지 1개 중 1개
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Mouth Replacement, Arms: 4 단계, 이미지 3개 중 1개 Teddy Ruxpin Mouth Replacement, Arms: 4 단계, 이미지 3개 중 2개 Teddy Ruxpin Mouth Replacement, Arms: 4 단계, 이미지 3개 중 3개
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Mouth Replacement: 5 단계, 이미지 1개 중 1개
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Mouth Replacement: 6 단계, 이미지 3개 중 1개 Teddy Ruxpin Mouth Replacement: 6 단계, 이미지 3개 중 2개 Teddy Ruxpin Mouth Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Mouth Replacement: 7 단계, 이미지 2개 중 1개 Teddy Ruxpin Mouth Replacement: 7 단계, 이미지 2개 중 2개
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Mouth Replacement: 8 단계, 이미지 2개 중 1개 Teddy Ruxpin Mouth Replacement: 8 단계, 이미지 2개 중 2개
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Mouth Replacement: 9 단계, 이미지 1개 중 1개
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Mouth Replacement, Housing Cover: 10 단계, 이미지 3개 중 1개 Teddy Ruxpin Mouth Replacement, Housing Cover: 10 단계, 이미지 3개 중 2개 Teddy Ruxpin Mouth Replacement, Housing Cover: 10 단계, 이미지 3개 중 3개
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Mouth Replacement, Eyes: 11 단계, 이미지 1개 중 1개
    • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
  12. Teddy Ruxpin Mouth Replacement: 12 단계, 이미지 2개 중 1개 Teddy Ruxpin Mouth Replacement: 12 단계, 이미지 2개 중 2개
    • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
  13. Teddy Ruxpin Mouth Replacement: 13 단계, 이미지 1개 중 1개
    • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
  14. Teddy Ruxpin Mouth Replacement, Mouth: 14 단계, 이미지 2개 중 1개 Teddy Ruxpin Mouth Replacement, Mouth: 14 단계, 이미지 2개 중 2개
    • Remove five 12.5mm Phillips #1 screws.
    • Pull the mouth mechanism out of the shell.
  15. Teddy Ruxpin Mouth Replacement: 15 단계, 이미지 2개 중 1개 Teddy Ruxpin Mouth Replacement: 15 단계, 이미지 2개 중 2개
    • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
    • Open the mouth mechanism
결론
작성자
3다른 기여자 명과 함께
Jayin Patel
회원 가입일: 01/23/20
406 평판
안내서 4개를 작성함
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 회원
CPSU-WHITE-W20S18G5
4 회원들
안내서 8개를 작성함
3가이드 댓글
His mouth and nose fell out leaving a hole in his face. How do i fix it or is the repair shop local? He is 30 years old.
rrhall559 - 답글
Mouth and nose fellout
rrhall559 - 답글
World of wonder made it and they aren’t in business anymore
rrhall559 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 37
전체 시간: 1,889
