소개
This guide will help you resolve any problem with your speaker on your Teddy Ruxpin model #17262DS. If the volume, sound quality, or general audio qualities of your bear are lacking this guide should help you fix those issues. A Phillips #1 screwdriver is required to complete this guide. Desoldering is also required so be sure to look at the desoldering guide for help.
필요한 것
Remove the vest covering the back of the bear.
Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
Unscrew the eleven circled 12.5mm Phillips #1 screws.
Remove the top of the housing to access the electronics inside.
Unscrew the two 12.5mm Phillips #1 screws holding the speaker cap on and remove the speaker cap.
다른 한 분이 해당 안내서를 완성하였습니다.
