주요 콘텐츠로 건너뛰기
Telstra Dave 4G ZTE T83 Back Speaker Replacement
필요한 것
  1. Telstra Dave 4G ZTE T83 Back Speaker Replacement, Outer Case: 1 단계, 이미지 3개 중 1개 Telstra Dave 4G ZTE T83 Back Speaker Replacement, Outer Case: 1 단계, 이미지 3개 중 2개 Telstra Dave 4G ZTE T83 Back Speaker Replacement, Outer Case: 1 단계, 이미지 3개 중 3개
    • Remove the four H2 screws from the back of the phone. Do not lose the black rubber rings on the screws.
    • Remove the two H2 screws, on either side of the phone. Do not lose the red seal that are on the screws.
    • Using a prying tool work off the back of the case. Ensuring not to lose the port covers. Be careful to note the position of connector covers. Have the tabs at the end of the connectors in place before clipping the phone completely back together.
  2. Telstra Dave 4G ZTE T83 Back Speaker Replacement, Battery Connector Cover: 2 단계, 이미지 1개 중 1개
    • Remove the two black Philips head screws from the battery connector cover.
    • Lift the battery cover away from the logic board
  3. Telstra Dave 4G ZTE T83 Back Speaker Replacement, Battery: 3 단계, 이미지 3개 중 1개 Telstra Dave 4G ZTE T83 Back Speaker Replacement, Battery: 3 단계, 이미지 3개 중 2개 Telstra Dave 4G ZTE T83 Back Speaker Replacement, Battery: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Disconnect the battery connector from the logic board. Do so by inserting a flat tool under the wires on the indicated side and wedging it up off the logic board.
    • Then remove the double sided tape using the blue tabs provided. Simply grab a tab and pull until it comes out tweezers are really good for beginning the process.
    • These pull tabs will need to be replaced with double sided tape on reassembly.
  4. Telstra Dave 4G ZTE T83 Back Speaker Replacement, Speaker: 4 단계, 이미지 1개 중 1개
    • Remove two black Phillips head screws and remove the back speaker assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ryan
회원 가입일: 08/19/15
1,519 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 573
