주요 콘텐츠로 건너뛰기
Telstra Dave 4G ZTE T83 Logic Board Replacement
필요한 것
  1. Telstra Dave 4G ZTE T83 Logic Board Replacement, Digitiser Cable: 1 단계, 이미지 1개 중 1개
    • Disconnect the digitizer cable from is socket, flip the brown clasp up from indicated edge and gently remove the cable.
  2. Telstra Dave 4G ZTE T83 Logic Board Replacement, Logic Board: 2 단계, 이미지 3개 중 1개 Telstra Dave 4G ZTE T83 Logic Board Replacement, Logic Board: 2 단계, 이미지 3개 중 2개 Telstra Dave 4G ZTE T83 Logic Board Replacement, Logic Board: 2 단계, 이미지 3개 중 3개
    • Be careful of LCD connector on the underside of the board through all of these steps (see green).
    • Separate the logic board from front display. Apply heat to the front glass to loosen the adhesive, using a prying tool to separate the board. Be careful and move slowly, it is very strong.
    • Be careful to remove the display first from the right side as there are clips along the left side.
    • Ensure not to damage the LCD cable, remove once accessible by releasing the brown clasp from indicated side.
결론
작성자
2다른 기여자 명과 함께
Ryan
회원 가입일: 08/19/15
1,519 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 393
