주요 콘텐츠로 건너뛰기
Texas Instruments TI-30 XS Multiview Battery Replacement
필요한 것
  1. Texas Instruments TI-30 XS Multiview Battery Replacement, Open the device: 1 단계, 이미지 1/2 Texas Instruments TI-30 XS Multiview Battery Replacement, Open the device: 1 단계, 이미지 2/2
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger to pry into the space between the blue back cover and the white body to take off the back cover.
  2. Texas Instruments TI-30 XS Multiview Battery Replacement, Open the battery compartiment: 2 단계, 이미지 1/1
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
  3. Texas Instruments TI-30 XS Multiview Battery Replacement, Eject the battery: 3 단계, 이미지 1/1
    • Use the spudger to lift the battery up from the black holder.
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Reverse the steps 2 and 1.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Nancy Ruiz
회원 가입일: 09/22/15
285 평판
안내서 1개 작성함
Cal Poly, Team 11-2, Forte Fall 2015 Cal Poly, Team 11-2, Forte Fall 2015 회원
CPSU-FORTE-F15S11G2
4 회원들
안내서 9개 작성하였습니다
댓글 9개
Hi, I followed your steps but my battery cover is not in the location that your photo indicates and the cover screws are not visible. There seems to be something covering them?
Why would my battery be situated next to the round black thing and yours is located above it at the top? If the calculator is a TI-XS 30 Multiview why on earth would they vary the orientation of internal components?
(I have had this calculator since 2006 - 12 years - it died this morning and I am disconsolate. Please help me figure out how to take the battery cover off or convince me to dispose of it.) ….I hate throwing away a good machine, even if I need to buy a more up to date graphing machine.
Eric of Ann Arbor
eric@engeltutors.com
Eric Engel - 답글
Please note - My battery screws (the ones that were inside the calculator next to battery) were actually glued over. I had to push the old battery out with my screw driver and push it out manually. It worked though. Glad I didn’t have to toss it, one less thing going into the land-field.
castanedaky36 - 답글
Wait a minute. Why does this calculator need a battery if it has a solar cell. It must be a fake solar cell to deceive.
Julio Lizzo - 답글
It charges the CR2032.
You can shine a light on the panel and remove the battery and the calculator will still work.
Steve Benitah -
It should be mentioned that you should insert a rechargable ML2032 instead of a common non-rechargable CR2032, since the solar panel will recharge the battery and standard CR2032 batteries are non-rechargable.
limsupsinx - 답글
댓글 쓰기
조회 통계:
24 시간 전: 26
7일 전: 212
30일 전: 931
전체 시간: 107,152
