주요 콘텐츠로 건너뛰기
Texas Instruments TI-30X IIS Solar Panel Replacement
필요한 것
  1. Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: 1 단계, 이미지 1/2 Texas Instruments TI-30X IIS Solar Panel Replacement, Solar Panel: 1 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the four 5 mm screws securing the back panel.
  2. Texas Instruments TI-30X IIS Solar Panel Replacement: 2 단계, 이미지 1/1
    • Wedge an opening tool in the gap between the front and back panel, then gently pry until the tabs release.
  3. Texas Instruments TI-30X IIS Solar Panel Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the two 3 mm screws securing the motherboard.
  4. Texas Instruments TI-30X IIS Solar Panel Replacement: 4 단계, 이미지 1/1
    • Desoldering and soldering presents a potential for device damage. Always solder/desolder in well-ventilated environments and with care not to burn yourself.
    • Desolder the positive the negative terminals on the motherboard.
  5. Texas Instruments TI-30X IIS Solar Panel Replacement: 5 단계, 이미지 1/2 Texas Instruments TI-30X IIS Solar Panel Replacement: 5 단계, 이미지 2/2
    • Gently lift up the front of the motherboard, at the top of the calculator.
    • Desolder the positive and negative terminals on the solar panel
    • Use the tip of a spudger to "walk" the solar panel out of its housing, by pushing it down through the two cutouts until it slides out of the bottom.
    • Remove the solar panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kameshwaran Balachandran
회원 가입일: 02/28/22
136 평판
안내서 1개 작성함
University of Memphis, Team 51-5, Willis Spring 2022 University of Memphis, Team 51-5, Willis Spring 2022 회원
UM-WILLIS-S22S51G5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 668
