주요 콘텐츠로 건너뛰기
The Sharper Image Literati Tablet Battery Replacement
필요한 것
  1. The Sharper Image Literati Tablet Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet Battery Replacement: 2 단계, 이미지 1/1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet Battery Replacement: 3 단계, 이미지 1/1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet Battery Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Spencer Dodder
회원 가입일: 03/21/18
560 평판
안내서 4개 작성하였습니다
IUPUI, Team S5-G4, Baechle Spring 2018 IUPUI, Team S5-G4, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 817
