주요 콘텐츠로 건너뛰기
The Sharper Image Literati Tablet Keyboard Replacement
필요한 것
  1. The Sharper Image Literati Tablet Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet Keyboard Replacement, SD Port: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet Keyboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet Keyboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the silver backing plate and the adhered SD port chip.
  13. The Sharper Image Literati Tablet Keyboard Replacement, Keyboard: 13 단계, 이미지 1개 중 1개
    • Remove the 10 Phillips head 4.2 mm screws using PH#00 screwdriver from the key board chip.
  14. The Sharper Image Literati Tablet Keyboard Replacement: 14 단계, 이미지 2개 중 1개 The Sharper Image Literati Tablet Keyboard Replacement: 14 단계, 이미지 2개 중 2개
    • Peal back the sensor array and keypad.
결론
작성자
2다른 기여자 명과 함께
Spencer Dodder
회원 가입일: 03/21/18
560 평판
안내서 4개를 작성함
IUPUI, Team S5-G4, Baechle Spring 2018 IUPUI, Team S5-G4, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G4
3 회원들
안내서 8개를 작성함
1가이드 댓글
This is NOT how you open them!!! I broke one of mine doing this. The white part SLIDES UP! DO not ply it open!!! Slide it up ( it needs a LITTLE ply around the silver part. ) It comes off then there are TWO SCREWS holding the brown part down. Once you remove the two screws ( they are under the white part ) then you can slide up the brown part too.
Phynix Heart - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 343
