주요 콘텐츠로 건너뛰기
The Sharper Image Literati Tablet SD Port Replacement
필요한 것
  1. The Sharper Image Literati Tablet SD Port Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet SD Port Replacement: 2 단계, 이미지 1개 중 1개
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet SD Port Replacement: 3 단계, 이미지 1개 중 1개
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet SD Port Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet SD Port Replacement, SD Port: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet SD Port Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet SD Port Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet SD Port Replacement: 8 단계, 이미지 1개 중 1개
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet SD Port Replacement: 9 단계, 이미지 1개 중 1개
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet SD Port Replacement: 10 단계, 이미지 1개 중 1개
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet SD Port Replacement: 11 단계, 이미지 1개 중 1개
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet SD Port Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the silver backing plate and the adhered SD port chip.
결론
작성자
2다른 기여자 명과 함께
Spencer Dodder
회원 가입일: 03/21/18
560 평판
안내서 4개를 작성함
IUPUI, Team S5-G4, Baechle Spring 2018 IUPUI, Team S5-G4, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G4
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 342
