주요 콘텐츠로 건너뛰기
Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement
필요한 것
  1. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: 2 단계, 이미지 1/2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: 2 단계, 이미지 2/2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, USB Cable Replacement: 3 단계, 이미지 1/2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, USB Cable Replacement: 3 단계, 이미지 2/2
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
  4. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: 4 단계, 이미지 1/2 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: 4 단계, 이미지 2/2
    • Desolder the black cable that connects the USB port to the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mario Nunez
회원 가입일: 10/18/17
421 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G33, Cagle Fall 2017 USF Tampa, Team S1-G33, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G33
4 회원들
안내서 5개 작성하였습니다
댓글 7개
kunt u mij vertellen waar ik het kabeltje kan kopen?
Rene
Rene Haeren - 답글
Can you advise on where to obtain a new usb cable please? (clentonmalcolm@gmail.com)
Malcolm Clenton - 답글
Have you solved it? I'm worried it's different from the regular usb line.
sunned -
Then wat where do u get usb cord to replace it some one plz explian
lilybaxter505 - 답글
Oh man.. the first comment about this was 2019 and we both are still waiting for an answer huh
Hez van der Meij -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 67
전체 시간: 8,987
