주요 콘텐츠로 건너뛰기
Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement
필요한 것
  1. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Safety precautions: 1 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Safety precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 2 단계, 이미지 3개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 2 단계, 이미지 3개 중 2개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 2 단계, 이미지 3개 중 3개
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 3 단계, 이미지 3개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 3 단계, 이미지 3개 중 2개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 3 단계, 이미지 3개 중 3개
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 4 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 5 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 5 단계, 이미지 2개 중 2개
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the tub: 6 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the tub: 6 단계, 이미지 2개 중 2개
    • Pull up on the brake lever to disengage the brake.
  7. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 7 단계, 이미지 3개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 7 단계, 이미지 3개 중 2개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 7 단계, 이미지 3개 중 3개
    • Rotate the tub until the yoke and dish assembly sit directly below the tub.
  8. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 8 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 8 단계, 이미지 2개 중 2개
    • Push down on the brake lever to re-engage the brake.
    • Make sure that the brake is fully engaged.
  9. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 9 단계, 이미지 3개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 9 단계, 이미지 3개 중 2개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 9 단계, 이미지 3개 중 3개
    • Use a 3/4 inch socket to remove the six nuts securing the tub to the dish.
  10. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the six drum clamp plates from the tub mounting points.
  11. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the tub up slightly by the gear ring to loosen the tub from the dish.
  12. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 12 단계, 이미지 3개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 12 단계, 이미지 3개 중 2개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 12 단계, 이미지 3개 중 3개
    • The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the tub straight up from the dish and remove it from the device.
  13. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the dish: 13 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the dish: 13 단계, 이미지 2개 중 2개
    • Use a large crescent wrench to remove the bolt securing the dish to the bottom of the yoke.
  14. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 14 단계, 이미지 1개 중 1개
    • Use a 3/4 inch socket to remove the lock bolt from the yoke.
  15. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 15 단계, 이미지 3개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 15 단계, 이미지 3개 중 2개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 15 단계, 이미지 3개 중 3개
    • The dish is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the dish straight up and remove it from the yoke.
    • A convenient place to set the dish is on top of the removed tub.
  16. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Reassembly tip: 16 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Reassembly tip: 16 단계, 이미지 2개 중 2개
    • During reassembly, be sure to align the shaft indent with the lock bolt hole as you set the dish in place. Otherwise, you will not be able to properly lock the shaft and tighten the dish bolt.
  17. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: 17 단계, 이미지 3개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: 17 단계, 이미지 3개 중 2개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: 17 단계, 이미지 3개 중 3개
    • Use a pipe wrench or an extra-large crescent wrench to loosen the dish plug.
    • Remove the dish plug.
  18. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 18 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 18 단계, 이미지 2개 중 2개
    • The spindle and bearings are very greasy. Handle these components carefully to avoid getting grease everywhere.
    • Push the spindle from the bottom of the dish.
  19. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 19 단계, 이미지 3개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 19 단계, 이미지 3개 중 2개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 19 단계, 이미지 3개 중 3개
    • Pull the spindle from the top of the dish and remove it.
    • After you reassemble the device, make sure to follow manufacturer instructions on how to properly lubricate the device with a grease gun.
  20. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle bearings: 20 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle bearings: 20 단계, 이미지 2개 중 2개
    • Pull and remove the bottom spindle bearing from the bottom of the dish.
  21. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 21 단계, 이미지 2개 중 1개 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: 21 단계, 이미지 2개 중 2개
    • Slide the top spindle bearing straight off the spindle and remove it.
결론
Arthur Shi
회원 가입일: 01/03/18
313,851 평판
안내서 729개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 32
전체 시간: 1,553
