주요 콘텐츠로 건너뛰기
Toshiba Chromebook 2 Motherboard Replacement
필요한 것
  1. Toshiba Chromebook 2 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Motherboard Replacement: 3 단계, 이미지 1/2 Toshiba Chromebook 2 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Motherboard Replacement: 4 단계, 이미지 1/2 Toshiba Chromebook 2 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 Toshiba Chromebook 2 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • Remove the 14 Phillips 2.34mm screws using the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the metal plate covering the motherboard by lifting it vertically.
  8. Toshiba Chromebook 2 Motherboard Replacement: 8 단계, 이미지 1/3 Toshiba Chromebook 2 Motherboard Replacement: 8 단계, 이미지 2/3 Toshiba Chromebook 2 Motherboard Replacement: 8 단계, 이미지 3/3
    • Flip up the plastic clamps holding down the 4 ribbon cables connected to the motherboard while gently pulling the ribbon cables from the sockets.
  9. Toshiba Chromebook 2 Motherboard Replacement: 9 단계, 이미지 1/3 Toshiba Chromebook 2 Motherboard Replacement: 9 단계, 이미지 2/3 Toshiba Chromebook 2 Motherboard Replacement: 9 단계, 이미지 3/3
    • Use the spudger to press down on the 2 white port cables, while also pulling each white port cable out of their sockets.
  10. Toshiba Chromebook 2 Motherboard Replacement: 10 단계, 이미지 1/3 Toshiba Chromebook 2 Motherboard Replacement: 10 단계, 이미지 2/3 Toshiba Chromebook 2 Motherboard Replacement: 10 단계, 이미지 3/3
    • Disconnect the motherboard from the 3 remaining cables by pulling the chords out of the sockets.
  11. Toshiba Chromebook 2 Motherboard Replacement: 11 단계, 이미지 1/2 Toshiba Chromebook 2 Motherboard Replacement: 11 단계, 이미지 2/2
    • Remove the motherboard by pulling upward and to the right.
    • Be careful not to damage the ports located on the left side of the motherboard during removal.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sam Nishi
회원 가입일: 10/06/16
485 평판
안내서 1개 작성함
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G4
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 21
전체 시간: 2,875
