주요 콘텐츠로 건너뛰기
Toshiba Chromebook 2 Motherboard Replacement
필요한 것
  1. Toshiba Chromebook 2 Motherboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Remove the 14 Phillips 2.34mm screws using the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the metal plate covering the motherboard by lifting it vertically.
  8. Toshiba Chromebook 2 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Toshiba Chromebook 2 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Toshiba Chromebook 2 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Flip up the plastic clamps holding down the 4 ribbon cables connected to the motherboard while gently pulling the ribbon cables from the sockets.
  9. Toshiba Chromebook 2 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Toshiba Chromebook 2 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Toshiba Chromebook 2 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Use the spudger to press down on the 2 white port cables, while also pulling each white port cable out of their sockets.
  10. Toshiba Chromebook 2 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Toshiba Chromebook 2 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Toshiba Chromebook 2 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Disconnect the motherboard from the 3 remaining cables by pulling the chords out of the sockets.
  11. Toshiba Chromebook 2 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the motherboard by pulling upward and to the right.
    • Be careful not to damage the ports located on the left side of the motherboard during removal.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sam Nishi
회원 가입일: 10/06/16
485 평판
안내서 1개를 작성함
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G4
4 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 3,118
