주요 콘텐츠로 건너뛰기
Toshiba Portege Z835-P330 Keyboard Replacement
필요한 것
  1. Toshiba Portege Z835-P330 Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver
  2. Toshiba Portege Z835-P330 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the hidden screw found in the middle of the back hard cover.
    • The hidden screw is found under the rubber cover shown in picture.
    • Here you will find a proprietary Japanese screw head.
    • Remove the screw with your own tool (not provided by IFixit) or by using the methods found here.
  3. Toshiba Portege Z835-P330 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Peel off the hardcover on the back of the device to expose the interior of the device.
    • Force may be required, but the hardcover should detach smoothly.
  4. Toshiba Portege Z835-P330 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the six screws using a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the white Bundled Cable Connector by gently pulling it out of the socket. Follow the guide here.
    • Plug should easily detach with little force.
  6. Toshiba Portege Z835-P330 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery up by its sides. The battery should easily come off.
  7. Toshiba Portege Z835-P330 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
  8. Toshiba Portege Z835-P330 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two cables by following the direction here.
    • The cables should come off easily.
  9. Toshiba Portege Z835-P330 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    • Flip the device over to access the keyboard.
    • Insert the Opening Tool into the crevice on one side of keyboard frame.
    • Pry off the keyboard using the tool.
  10. Toshiba Portege Z835-P330 Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Pull off the rest of the keyboard with your hands when you're able to easily grab underneath the keyboard.
    • The keyboard will be taped underneath but will easily detach.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dominic Whiting
회원 가입일: 02/08/18
927 평판
안내서 5개를 작성함
댓글 2개
Ordering the parts for my wife’s Toshiba shortly. It has been an excellent machine but the keyboard keys have worn off. Seems like a very straight forward process. The question that I have is what do I use to hold the keyboard back in place?
Thanks for the directions. George
George Bootes - 답글
Only one key gets off the keyboard (down cursor) I’ve got the key and the rounded rubber that fits into the mechanism, most of the time it works but when I press continusly it gets off.
Is there a way to fix it without changing the whole keyboard?
Jesús Fernández Sánchez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 28
전체 시간: 1,782
