이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The hard drive is the storage space of your computer, containing your music, photos, programs, and documents. It also houses your operating system. Save all the files you want to keep on an external device before installing a new hard drive, as replacing the hard drive basically gives you a new computer.
필요한 것
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Unscrew the 4 mm screw with the Philips #1 screwdriver.
Lift and remove the hard drive cover.
다른 한 분이 해당 안내서를 완성하였습니다.
