주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-A5108 Heat Sink Replacement
필요한 것
  1. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Battery: 1 단계, 이미지 1/1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Heat Sink Replacement: 2 단계, 이미지 1/1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Heat Sink Replacement: 3 단계, 이미지 1/1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Heat Sink Replacement: 5 단계, 이미지 1/1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: 6 단계, 이미지 1/3 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: 6 단계, 이미지 2/3 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Back Cover: 6 단계, 이미지 3/3
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Heat Sink Replacement, Heat Sink: 7 단계, 이미지 1/2 Toshiba Satellite C55D-A5108 Heat Sink Replacement, Heat Sink: 7 단계, 이미지 2/2
    • Remove the four Phillips #0 screws from each corner of the heat sink.
    • Gently lift the heat sink out of the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Smith
회원 가입일: 10/25/19
187 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 281
