주요 콘텐츠로 건너뛰기
Toshiba Satellite C655D-S5200 LCD Replacement
필요한 것
  1. Toshiba Satellite C655D-S5200 LCD Replacement, LCD: 1 단계, 이미지 3개 중 1개 Toshiba Satellite C655D-S5200 LCD Replacement, LCD: 1 단계, 이미지 3개 중 2개 Toshiba Satellite C655D-S5200 LCD Replacement, LCD: 1 단계, 이미지 3개 중 3개
    • Here is the Toshiba Satellite C655D-S5200
    • Open the laptop with the LCD facing forward. There are four rubber caps, one in each corner
    • Removing the plugs reveal the Phillips screws
  2. Toshiba Satellite C655D-S5200 LCD Replacement: 2 단계, 이미지 3개 중 1개 Toshiba Satellite C655D-S5200 LCD Replacement: 2 단계, 이미지 3개 중 2개 Toshiba Satellite C655D-S5200 LCD Replacement: 2 단계, 이미지 3개 중 3개
    • Remove all four screws, tow on top left and right corner
    • One on the bottom left corner
    • and the bottom right corner.
    • Here are the four M3x5mm screws
  3. Toshiba Satellite C655D-S5200 LCD Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite C655D-S5200 LCD Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite C655D-S5200 LCD Replacement: 3 단계, 이미지 3개 중 3개
    • Use a plastic opening tool, or similar to pop the bezel of the LCD assembly
    • Continue to slide the tool all the way across the top
    • Once the bezel has been released from the tabs, it can be further released be applying some gently manual pulling
  4. Toshiba Satellite C655D-S5200 LCD Replacement: 4 단계, 이미지 3개 중 1개 Toshiba Satellite C655D-S5200 LCD Replacement: 4 단계, 이미지 3개 중 2개 Toshiba Satellite C655D-S5200 LCD Replacement: 4 단계, 이미지 3개 중 3개
    • Continue to pull gently on the sides
    • and finally on the bottom.
    • With all the tabs released the bezel can now be removed.
  5. Toshiba Satellite C655D-S5200 LCD Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Satellite C655D-S5200 LCD Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Satellite C655D-S5200 LCD Replacement: 5 단계, 이미지 3개 중 3개
    • Here is the LCD assembly without the bezel
    • Remove the Phillips screw that connects the LCD frame to the back cover. This is the left one
    • Remove the right one as well
  6. Toshiba Satellite C655D-S5200 LCD Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Satellite C655D-S5200 LCD Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Satellite C655D-S5200 LCD Replacement: 6 단계, 이미지 3개 중 3개
    • The LCD can now be moved forward and away from the rear cover
    • There are three screws on either side that hold the panel to the frame. Remove those
    • Here are the three M2x4 screws
  7. Toshiba Satellite C655D-S5200 LCD Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Satellite C655D-S5200 LCD Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Satellite C655D-S5200 LCD Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the three Phillips screws on the right side as well.
    • with the screws removed the panel can now be moved out of the LCD frame. The LCD is still connected by the display cable.
    • The display cable is secured to the connector with some clear adhesive. Remove this frist
  8. Toshiba Satellite C655D-S5200 LCD Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Satellite C655D-S5200 LCD Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the display cable carefully.
    • With the display cable disconnected, the LCD can now be removed and replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
812,277 평판
안내서 119개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 11
전체 시간: 1,605
