이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Keeping your laptop cool is important to the speed and functionality of the device. This guide will show you how to replace your Toshiba's cooling fans.
필요한 것
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
