주요 콘텐츠로 건너뛰기
Toshiba Satellite C875-S7304 Display Replacement
필요한 것
  1. Toshiba Satellite C875-S7304 Display Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite C875-S7304 Display Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite C875-S7304 Display Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Display Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite C875-S7304 Display Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Display Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Display Replacement: 4 단계, 이미지 1개 중 1개
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Display Replacement, Display: 6 단계, 이미지 2개 중 1개 Toshiba Satellite C875-S7304 Display Replacement, Display: 6 단계, 이미지 2개 중 2개
    • Carefully flip the device back over so that the 'TOSHIBA' logo faces away from you.
    • Open the laptop to show the display.
  7. Toshiba Satellite C875-S7304 Display Replacement: 7 단계, 이미지 1개 중 1개
    • Use the spudger to remove the screw covers and then remove the screws using the Phillips #1.
  8. Toshiba Satellite C875-S7304 Display Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Satellite C875-S7304 Display Replacement: 8 단계, 이미지 2개 중 2개
    • Using the iFixit opening tool, carefully remove the plastic frame from the display.
  9. Toshiba Satellite C875-S7304 Display Replacement: 9 단계, 이미지 1개 중 1개
    • Remove two screws from each hinge on either side using the Phillips #1 screwdriver.
    • There are two screws on each hinge.
  10. Toshiba Satellite C875-S7304 Display Replacement: 10 단계, 이미지 1개 중 1개
    • Rotate the laptop so that the side is facing you.
    • Remove the three screws using the Phillips #1 screwdriver on each side of the display.
    • There will be six total screws removed in this step (three on each side face).
  11. Toshiba Satellite C875-S7304 Display Replacement: 11 단계, 이미지 1개 중 1개
    • Turn the display over to expose the wiring on the other side.
  12. Toshiba Satellite C875-S7304 Display Replacement: 12 단계, 이미지 2개 중 1개 Toshiba Satellite C875-S7304 Display Replacement: 12 단계, 이미지 2개 중 2개
    • Gently loosen the sliding bracket and remove the cable.
    • If you want to use the same webcam, disconnect it from the back of the display.
  13. Toshiba Satellite C875-S7304 Display Replacement: 13 단계, 이미지 1개 중 1개
    • With the display now fully disconnected, carefully remove it from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nathan Gareri
회원 가입일: 09/04/19
211 평판
안내서 1개를 작성함
댓글 한 개
I love this site....best
Hafiz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 51
전체 시간: 1,154
