주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5895 CD Drive Replacement CD Drive Replacement
필요한 것
  1. Toshiba Satellite L305D-S5895 CD Drive Replacement CD Drive Replacement, CD Drive: 1 단계, 이미지 1/1
  2. Toshiba Satellite L305D-S5895 CD Drive Replacement CD Drive Replacement: 2 단계, 이미지 1/1
    • Undo screw with your Phillips #0 screwdriver.
  3. Toshiba Satellite L305D-S5895 CD Drive Replacement CD Drive Replacement: 3 단계, 이미지 1/1
    • Push out CD Drive using your finger.
    • You will have to go underneath the plastic cover of the laptop to access it, as shown in the picture.
  4. Toshiba Satellite L305D-S5895 CD Drive Replacement CD Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L305D-S5895 CD Drive Replacement CD Drive Replacement: 4 단계, 이미지 2/2
    • Use your fingers to pull out the CD Drive by the face of the drive.
결론
Nathan Merlan
회원 가입일: 10/19/16
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 UMass Dartmouth, Team 2-8, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G8
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 180
