주요 콘텐츠로 건너뛰기
Toshiba Satellite L55-A RAM Module Replacement
필요한 것
  1. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM cover: 1 단계, 이미지 1/1
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A RAM Module Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L55-A RAM Module Replacement: 2 단계, 이미지 2/2
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: 3 단계, 이미지 1/3 Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: 3 단계, 이미지 2/3 Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: 3 단계, 이미지 3/3
    • This step shows how to remove a RAM module.
    • Use your fingers to spread the two metal clips securing the edge of the RAM module. This should free the module and cause it to pop up slightly.
    • Pull the RAM module out of its slot and remove it.
  4. Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: 4 단계, 이미지 1/3 Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: 4 단계, 이미지 2/3 Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: 4 단계, 이미지 3/3
    • This step shows how to insert a RAM module.
    • Insert the replacement RAM at a shallow angle into the RAM slot until the gold contacts are fully socketed.
    • Use your fingers to gently press the RAM module's edges down until both metal clips snap into place.
    • If your laptop will not properly recognize the installed RAM, unseat and reseat the RAM, making sure that all modules are fully locked in place.
결론
Arthur Shi
회원 가입일: 01/03/18
254,121 평판
안내서 529개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 227
