주요 콘텐츠로 건너뛰기
Toshiba Satellite M45 Motherboard Replacement
필요한 것
  1. Toshiba Satellite M45 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure device is off and power supply is disconnected.
    • Flip the laptop to the bottom side.
    • Locate and slide the two battery locks to disconnect the battery.
    • Remove the battery by sliding it out away from the computer (horizontal with the casing).
  2. Toshiba Satellite M45 Motherboard Replacement, RAM: 2 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement, RAM: 2 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement, RAM: 2 단계, 이미지 3/3
    • Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
    • Then, use a the blue iFixit Opening Tool to pry the cover panel off.
    • Push on to the RAM tabs to disconnect the RAM form the device.
    • The RAM will pop off from the socket. Gently pull the RAM out of the socket.
  3. Toshiba Satellite M45 Motherboard Replacement, Wi-Fi Card: 3 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement, Wi-Fi Card: 3 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement, Wi-Fi Card: 3 단계, 이미지 3/3
    • Use the #1 Phillips head screwdriver to unscrew the panel.
    • Disconnect the black and white wires.
    • Push on the tabs to disconnect the Wi-Fi card.
    • Use the blue iFixit Opening Tool to pull the Wi-Fi Card out.
  4. Toshiba Satellite M45 Motherboard Replacement, Hard Drive: 4 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement, Hard Drive: 4 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Use the #1 Phillips head screwdriver as to remove the hard drive screw.
    • Use the blue iFixit Opening Tool to pry the cover off.
    • Use the plastic flap to pull the hard drive out of its slot.
  5. Toshiba Satellite M45 Motherboard Replacement, Optical Drive: 5 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement, Optical Drive: 5 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement, Optical Drive: 5 단계, 이미지 3/3
    • Use the #1 Phillips head screwdriver remove the Optical Drive screw.
    • Use the blue iFixit Opening Tool to pry the Optical Drive out of the slot from the side of the casing.
    • Use your hands to pull the rest of the Optical Drive out.
  6. Toshiba Satellite M45 Motherboard Replacement, Keyboard: 6 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement, Keyboard: 6 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement, Keyboard: 6 단계, 이미지 3/3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  7. Toshiba Satellite M45 Motherboard Replacement: 7 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement: 7 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement: 7 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  8. Toshiba Satellite M45 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement, Motherboard: 8 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement, Motherboard: 8 단계, 이미지 3/3
    • Disconnect the video cable, then slowly and firmly pull the video cable upwards.
    • Disconnect the brown ribbon located in the middle area of the laptop.
    • Disconnect the two white ribbons located in the bottom left of the laptop.
    • Firmly pull out the two white ribbons.
  9. Toshiba Satellite M45 Motherboard Replacement: 9 단계, 이미지 1/2 Toshiba Satellite M45 Motherboard Replacement: 9 단계, 이미지 2/2
    • Use the Phillips #00 Screwdriver to unscrew all the screws.
    • Unscrew three additional screws through the three holes on the optical drive.
  10. Toshiba Satellite M45 Motherboard Replacement: 10 단계, 이미지 1/3 Toshiba Satellite M45 Motherboard Replacement: 10 단계, 이미지 2/3 Toshiba Satellite M45 Motherboard Replacement: 10 단계, 이미지 3/3
    • Turn the laptop upside down.
    • Use the blue iFixit Opening Tool to slowly pry the case upward.
    • Remove the white ribbon
    • Make sure to completely remove the white ribbon and set it to the right side of the motherboard. and not on top of the motherboard.
  11. Toshiba Satellite M45 Motherboard Replacement: 11 단계, 이미지 1/2 Toshiba Satellite M45 Motherboard Replacement: 11 단계, 이미지 2/2
    • Lift up the motherboard.
    • Be careful not to rip out small components on the motherboard. Carefully remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 04/16/10
127 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-42, Garner Spring 2010 Cal Poly, Team 10-42, Garner Spring 2010 회원
CPSU-GARNER-S10S10G42
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 19,497
