소개
Replacing a broken or damaged battery can increase the lifespan of your laptop and improve performance. In this guide we will show you how to replace your Toshiba Satellite battery. We will first open the back of the laptop. After, we will carefully unscrew and remove the battery for replacement.
필요한 것
Remove the bottom cover of your laptop. For instructions on how to do this, take a look at the Toshiba Satellite P55-A5312 Back Cover Removal Guide
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - 답글
