주요 콘텐츠로 건너뛰기
Toshiba Satellite P55-A5312 Battery Replacement
필요한 것
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite P55-A5312 Battery Replacement, Battery: 1 단계, 이미지 2/2
  2. Toshiba Satellite P55-A5312 Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite P55-A5312 Battery Replacement: 2 단계, 이미지 2/2
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: 3 단계, 이미지 1/1
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: 4 단계, 이미지 1/1
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the laptop after it has been completely disconnected.
결론
다른 5명이 해당 안내서를 완성하였습니다.
ohatae
회원 가입일: 01/25/17
294 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G1
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 5,817
