주요 콘텐츠로 건너뛰기
Toshiba Satellite P55-A5312 CD Drive Replacement
필요한 것
  1. Toshiba Satellite P55-A5312 CD Drive Replacement, CD Drive: 1 단계, 이미지 1/2 Toshiba Satellite P55-A5312 CD Drive Replacement, CD Drive: 1 단계, 이미지 2/2
  2. Toshiba Satellite P55-A5312 CD Drive Replacement: 2 단계, 이미지 1/1
    • Locate the CD drive at the lower right hand corner of the laptop.
    • Unscrew any screws that are holding the drive in place. However, there should only be one. The other screws holding the drive in place are also responsible for holding the bottom casing.
  3. Toshiba Satellite P55-A5312 CD Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite P55-A5312 CD Drive Replacement: 3 단계, 이미지 2/2
    • Carefully remove the CD drive by pulling it from its connection to the motherboard.
    • Replace it by inserting a new CD drive and replacing any screws you have removed.
결론
ohatae
회원 가입일: 01/25/17
294 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 726
