주요 콘텐츠로 건너뛰기
Toshiba Satellite P55-A5312 Fan Replacement
필요한 것
  1. Toshiba Satellite P55-A5312 Fan Replacement, Fan: 1 단계, 이미지 1/3 Toshiba Satellite P55-A5312 Fan Replacement, Fan: 1 단계, 이미지 2/3 Toshiba Satellite P55-A5312 Fan Replacement, Fan: 1 단계, 이미지 3/3
  2. Toshiba Satellite P55-A5312 Fan Replacement: 2 단계, 이미지 1/1
    • Locate the 2.5x6mm black screw to the bottom of the tri-colored wires that holds down the fan to the motherboard.
    • Unscrew it with a Philips #0 screwdriver.
  3. Toshiba Satellite P55-A5312 Fan Replacement: 3 단계, 이미지 1/1
    • Locate the 4 2x3mm screws holding down the orange heatsink.
    • Unscrew them with a Philips #0 screwdriver.
  4. Toshiba Satellite P55-A5312 Fan Replacement: 4 단계, 이미지 1/1
    • Remove the white holder of the red, yellow, and black wires from the beige piece by gently pulling on it.
  5. Toshiba Satellite P55-A5312 Fan Replacement: 5 단계, 이미지 1/1
    • Carefully remove the fan from its seating with your hands.
    • Replace with your new fan.
결론
Aniketh Bhat
회원 가입일: 01/25/17
216 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 941
