주요 콘텐츠로 건너뛰기
Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement
필요한 것
  1. Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement, Wi-Fi/Bluetooth Card: 1 단계, 이미지 1/2 Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement, Wi-Fi/Bluetooth Card: 1 단계, 이미지 2/2
  2. Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement: 2 단계, 이미지 1/1
    • Locate the Wi-Fi/Bluetooth card, and remove the two wires connected to the card with your hands.
  3. Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement: 3 단계, 이미지 1/1
    • Unscrew the single 2.5x6mm holding down the card onto the board with your Philips #0 screwdriver.
  4. Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement: 4 단계, 이미지 1/1
    • Remove/unhinge the card from the board by gently lifting it upwards.
    • Replace it with your new card.
결론
Aniketh Bhat
회원 가입일: 01/25/17
216 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 1,633
