주요 콘텐츠로 건너뛰기
Toshiba Satellite S55T-B5335 Motherboard Replacement
필요한 것
  1. Toshiba Satellite S55T-B5335 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Motherboard Replacement: 2 단계, 이미지 1/3 Toshiba Satellite S55T-B5335 Motherboard Replacement: 2 단계, 이미지 2/3 Toshiba Satellite S55T-B5335 Motherboard Replacement: 2 단계, 이미지 3/3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Motherboard Replacement, Bottom Cover: 3 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Motherboard Replacement, Bottom Cover: 3 단계, 이미지 2/2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Motherboard Replacement: 4 단계, 이미지 1/1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Motherboard Replacement: 5 단계, 이미지 1/1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Motherboard Replacement, Cooling Fans: 6 단계, 이미지 1/1
    • Remove the two 3.5 mm Phillips #1 screws that hold the cooling fan in place.
  7. Toshiba Satellite S55T-B5335 Motherboard Replacement: 7 단계, 이미지 1/1
    • Wedge the flat end of the spudger between the connector and its socket.
    • Twist back and forth in order to pry the connector loose from its socket.
    • Although you can pull on the connector wires to remove it from the socket, it is not recommended until the connector is loose to prevent damage to the wires.
  8. Toshiba Satellite S55T-B5335 Motherboard Replacement: 8 단계, 이미지 1/1
    • Lift up on the cooling fan to remove it from the laptop.
    • Repeat steps 6-8 for the other cooling fan.
  9. Toshiba Satellite S55T-B5335 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/1
    • Remove the three 4 mm Phillips #1 screws holding the motherboard in place.
  10. Toshiba Satellite S55T-B5335 Motherboard Replacement: 10 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the four 4 mm Phillips #1 screws mounting the heat sink to the motherboard.
  11. Toshiba Satellite S55T-B5335 Motherboard Replacement: 11 단계, 이미지 1/1
    • Gently lift on either side of the heat sink to separate it from the laptop.
    • When reassembling the device, be sure to apply new thermal paste to the heat sink and processor.
  12. Toshiba Satellite S55T-B5335 Motherboard Replacement: 12 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Motherboard Replacement: 12 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • On all ZIF (Zero Insertion Force) connectors, use a spudger to lift the lock.
    • Use tweezers to pull on the designated pull tab to remove each ZIF connector.
  13. Toshiba Satellite S55T-B5335 Motherboard Replacement: 13 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Motherboard Replacement: 13 단계, 이미지 2/2
    • On all No-Fuss Ribbon Cable Connectors use tweezers, on the designated tabs, to remove them.
  14. Toshiba Satellite S55T-B5335 Motherboard Replacement: 14 단계, 이미지 1/1
    • Lift on the motherboard from the USB port area while pulling the frame away from motherboard.
  15. Toshiba Satellite S55T-B5335 Motherboard Replacement: 15 단계, 이미지 1/3 Toshiba Satellite S55T-B5335 Motherboard Replacement: 15 단계, 이미지 2/3 Toshiba Satellite S55T-B5335 Motherboard Replacement: 15 단계, 이미지 3/3
    • Once all connectors are separated from the motherboard and the USB port area is freed, carefully lift on either side of the motherboard to remove it.
결론
George Gillespie
회원 가입일: 09/15/16
721 평판
안내서 7개 작성하였습니다
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G1
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Hello
I got to this address through my search for a motherboard for toshiba satellite c55
Can you tell me where to buy it because the one that I own has broken down
Thank you
akad100@gmail.com
alakad100 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 26
전체 시간: 2,751
