주요 콘텐츠로 건너뛰기
Toshiba Tecra M2 CPU Replacement
필요한 것
  1. Toshiba Tecra M2 CPU Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the laptop upside down so the back compartment is facing up.
    • Place left thumb on the battery lock tab.
    • Place right thumb on the battery release latch.
  2. Toshiba Tecra M2 CPU Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Tecra M2 CPU Replacement: 2 단계, 이미지 2개 중 2개
    • Slide both tabs outward at the same time to release battery pack.
  3. Toshiba Tecra M2 CPU Replacement: 3 단계, 이미지 1개 중 1개
    • Pull out the battery after it has popped out and set aside.
    • The battery and the battery cover are in one piece
  4. Toshiba Tecra M2 CPU Replacement, CPU: 4 단계, 이미지 1개 중 1개
    • Use a #00 phillips head screwdriver to remove the 8mm screw for the keyboard strip located under the battery.
  5. Toshiba Tecra M2 CPU Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the device over and open it up to the display.
    • Gently lift a corner of the keyboard strip until it pops out of its position.
  6. Toshiba Tecra M2 CPU Replacement: 6 단계, 이미지 1개 중 1개
    • Using a #00 phillips head screwdriver, remove the two 4mm screws found underneath the keyboard strip.
  7. Toshiba Tecra M2 CPU Replacement: 7 단계, 이미지 2개 중 1개 Toshiba Tecra M2 CPU Replacement: 7 단계, 이미지 2개 중 2개
    • Pop the keyboard up gently and rest on top of the touch pad
    • The keyboard is attached underneath by a thin film. Do not rip the keyboard off. Gently lay it down without ripping the film.
  8. Toshiba Tecra M2 CPU Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Tecra M2 CPU Replacement: 8 단계, 이미지 2개 중 2개
    • Using a #00 phillips head screwdriver, remove the 6mm screw holding the metal plate down.
  9. Toshiba Tecra M2 CPU Replacement: 9 단계, 이미지 2개 중 1개 Toshiba Tecra M2 CPU Replacement: 9 단계, 이미지 2개 중 2개
    • Gently remove the keyboard connector film from the motherboard with fingers by lifting upwards.
    • Set aside the keyboard.
  10. Toshiba Tecra M2 CPU Replacement: 10 단계, 이미지 1개 중 1개
    • Using a #00 phillips head screwdriver, remove the three 13mm screws holding down the touch pad's frame from underneath the keyboard.
  11. Toshiba Tecra M2 CPU Replacement: 11 단계, 이미지 3개 중 1개 Toshiba Tecra M2 CPU Replacement: 11 단계, 이미지 3개 중 2개 Toshiba Tecra M2 CPU Replacement: 11 단계, 이미지 3개 중 3개
    • Flip laptop back upside down.
    • Remove the 5mm lock screw, using a #00 phillips head screwdriver.
    • Slide bay latch toward the battery compartment.
    • Remove CD-RW/DVD-ROM drive.
  12. Toshiba Tecra M2 CPU Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the 4.5mm screw located under the CD-RW/DVD-ROM drive compartment, using a #00 phillips head screwdriver.
  13. Toshiba Tecra M2 CPU Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the three 17mm screws found on the backside of the laptop using a #00 phillips head screwdriver.
    • Remove the ten 8mm screws using a #00 phillips head screwdriver.
  14. Toshiba Tecra M2 CPU Replacement: 14 단계, 이미지 2개 중 1개 Toshiba Tecra M2 CPU Replacement: 14 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Flip the laptop back over and unplug the touch pad's power cord from the motherboard gently using a pair of tweezers.
  15. Toshiba Tecra M2 CPU Replacement: 15 단계, 이미지 2개 중 1개 Toshiba Tecra M2 CPU Replacement: 15 단계, 이미지 2개 중 2개
    • Lift off the plastic cover and set it aside.
  16. Toshiba Tecra M2 CPU Replacement: 16 단계, 이미지 2개 중 1개 Toshiba Tecra M2 CPU Replacement: 16 단계, 이미지 2개 중 2개
    • Using a #00 phillips head screwdriver, unscrew the three 5mm screws holding down the heat sink securing bracket.
    • Lift off the securing bracket and set aside.
  17. Toshiba Tecra M2 CPU Replacement: 17 단계, 이미지 1개 중 1개
    • Wiggle the heat sink until it lifts off the top of your CPU. There is thermal paste underneath and it may stick.
  18. Toshiba Tecra M2 CPU Replacement: 18 단계, 이미지 3개 중 1개 Toshiba Tecra M2 CPU Replacement: 18 단계, 이미지 3개 중 2개 Toshiba Tecra M2 CPU Replacement: 18 단계, 이미지 3개 중 3개
    • Turn a flathead #3 screwdriver counter-clockwise to unlock the CPU socket.
    • Grab the CPU with your index finger and thumb and pull directly upwards.
    • Apply a new coat of thermal paste before reassembling.
    • How to Apply Thermal Paste
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Cindy Nguyen
회원 가입일: 09/08/14
386 평판
안내서 3개를 작성함
CSU Fullerton, Team 1-6, Bruce Fall 2014 CSU Fullerton, Team 1-6, Bruce Fall 2014 회원
CSUF-BRUCE-F14S1G6
3 회원들
안내서 9개를 작성함
댓글 한 개
"Step 4 - CPU" THAT IS NOT A 8MM SCREW! THERE IS NOW A HOLE IN MY COMPUTER!!
[deleted] - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 1,686
