주요 콘텐츠로 건너뛰기
Toshiba Tecra Z50-A Battery Replacement
필요한 것
  1. Toshiba Tecra Z50-A Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Battery Replacement: 2 단계, 이미지 1/1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Battery Replacement: 4 단계, 이미지 1/1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Battery Replacement: 5 단계, 이미지 1/1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Battery Replacement: 6 단계, 이미지 1/1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Battery Replacement: 7 단계, 이미지 1/1
    • Lift up on the battery with your hands and remove it from the laptop.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 한 분이 해당 안내서를 완성하였습니다.
Dominic Hryzan
회원 가입일: 10/25/21
569 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G4
3 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 29
전체 시간: 979
