주요 콘텐츠로 건너뛰기
Toshiba Tecra Z50-A Motherboard Replacement
필요한 것
  1. Toshiba Tecra Z50-A Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Motherboard Replacement: 2 단계, 이미지 1/1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Motherboard Replacement, Battery: 3 단계, 이미지 1/1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Motherboard Replacement: 4 단계, 이미지 1/1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Motherboard Replacement: 7 단계, 이미지 1/1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Motherboard Replacement, CPU Fan and Heat Sink: 8 단계, 이미지 1/1
    • Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
  9. Toshiba Tecra Z50-A Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the two 4 mm screws from the fan using a Phillips #0 screwdriver.
  10. Toshiba Tecra Z50-A Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the heat sink from the laptop.
  11. Toshiba Tecra Z50-A Motherboard Replacement: 11 단계, 이미지 1/1
    • Pull towards the bottom of the laptop to disconnect the fan cable from its connector on the motherboard.
  12. Toshiba Tecra Z50-A Motherboard Replacement: 12 단계, 이미지 1/1
    • Lift up on the fan and remove it from the laptop.
    • When replacing the fan and heat sink, be sure to reapply thermal paste.
  13. Toshiba Tecra Z50-A Motherboard Replacement, Motherboard: 13 단계, 이미지 1/1
    • Remove the two 5 mm screws using a Phillips #0 screwdriver.
  14. Toshiba Tecra Z50-A Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the three 5 mm screws using a Phillips #0 screwdriver.
  15. Toshiba Tecra Z50-A Motherboard Replacement: 15 단계, 이미지 1/1
    • Lift up on plastic covering over the Wi-Fi card.
    • Disconnect the black and white coaxial cables from the Wi-Fi card.
  16. Toshiba Tecra Z50-A Motherboard Replacement: 16 단계, 이미지 1/1
    • Unplug the bundled red and black cable from its connector on the motherboard.
  17. Toshiba Tecra Z50-A Motherboard Replacement: 17 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Lift up on the black retaining flap using a pair of tweezers.
  18. Toshiba Tecra Z50-A Motherboard Replacement: 18 단계, 이미지 1/1
    • Push the tab on the right toward the top of the laptop.
  19. Toshiba Tecra Z50-A Motherboard Replacement: 19 단계, 이미지 1/1
    • Push the tab on the left toward the top of the laptop.
  20. Toshiba Tecra Z50-A Motherboard Replacement: 20 단계, 이미지 1/1
  21. Toshiba Tecra Z50-A Motherboard Replacement: 21 단계, 이미지 1/1
  22. Toshiba Tecra Z50-A Motherboard Replacement: 22 단계, 이미지 1/1
    • Lift up on the charging port with tweezers.
  23. Toshiba Tecra Z50-A Motherboard Replacement: 23 단계, 이미지 1/1
    • Lift up on the plastic tab.
  24. Toshiba Tecra Z50-A Motherboard Replacement: 24 단계, 이미지 1/1
    • Pull plug towards the bottom of the laptop.
  25. Toshiba Tecra Z50-A Motherboard Replacement: 25 단계, 이미지 1/1
    • Grab the middle of the motherboard with your hands and lift up to remove it from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Luis Juen Baez
회원 가입일: 10/25/21
585 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G4
3 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 33
전체 시간: 845
