소개
- The motherboard of a laptop is a vital piece of your computer, if you find that the performance or functionality of your device is limited, then it may be time for the part to be replaced.
- If you are positive that the motherboard of your Toshiba Tecra z50-a is damaged or causing issues, then it’s time for it to be replaced. Follow this guide to learn how to replace the motherboard of the laptop.
- Before disassembling the laptop, ensure it is powered off and nothing is plugged into the device.
- Remove any rings, bracelets, or any other metal objects from your hands.
필요한 것
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
