주요 콘텐츠로 건너뛰기
Trio Stealth G4 Motherboard Replacement
필요한 것
  1. Trio Stealth G4 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Working on your device while it is turned on may result in electric shock. Be sure to shut down and unplug your device before you begin.
    • Flip your tablet over so that the back panel is facing up.
  2. Trio Stealth G4 Motherboard Replacement: 2 단계, 이미지 1/2 Trio Stealth G4 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
    • Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
  3. Trio Stealth G4 Motherboard Replacement: 3 단계, 이미지 1/1
    • Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
    • The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
  4. Trio Stealth G4 Motherboard Replacement: 4 단계, 이미지 1/2 Trio Stealth G4 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the back panel from the rest of the tablet and set it aside.
  5. Trio Stealth G4 Motherboard Replacement: 5 단계, 이미지 1/1
    • The plastic volume button cover may fall out when you remove the back panel. Set it aside.
  6. Trio Stealth G4 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Trio Stealth G4 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Trio Stealth G4 Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove the 4 pieces of tape covering the zero insertion force (ZIF) connectors on the motherboard.
  7. Trio Stealth G4 Motherboard Replacement: 7 단계, 이미지 1/3 Trio Stealth G4 Motherboard Replacement: 7 단계, 이미지 2/3 Trio Stealth G4 Motherboard Replacement: 7 단계, 이미지 3/3
    • Use a spudger to flip up the black flaps on each of the 4 ZIF connectors.
    • Once the flaps are up, use your fingers to disconnect the end of the ribbon wires from the connectors.
  8. Trio Stealth G4 Motherboard Replacement: 8 단계, 이미지 1/2 Trio Stealth G4 Motherboard Replacement: 8 단계, 이미지 2/2
    • Use the soldering iron to melt away the solder from each of the wires connecting to the motherboard.
    • Once the solder is completely removed, pull the wires away from the motherboard.
  9. Trio Stealth G4 Motherboard Replacement: 9 단계, 이미지 1/2 Trio Stealth G4 Motherboard Replacement: 9 단계, 이미지 2/2
    • Use a J00 Phillips head screwdriver to remove the two 4.3 mm screws securing the motherboard to the device and set them aside.
  10. Trio Stealth G4 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the silver piece of tape from the left edge of the motherboard.
  11. Trio Stealth G4 Motherboard Replacement: 11 단계, 이미지 1/2 Trio Stealth G4 Motherboard Replacement: 11 단계, 이미지 2/2
    • Use a spudger to lift the motherboard from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matt Arnold
회원 가입일: 09/22/15
607 평판
안내서 5개 작성하였습니다
Baylor, Team 4-1, Williams Fall 2015 Baylor, Team 4-1, Williams Fall 2015 회원
BU-WILLIAMS-F15S4G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 895
