주요 콘텐츠로 건너뛰기
Trio Stealth-10 Screen/Digitizer Replacement
필요한 것
  1. Trio Stealth-10 Screen/Digitizer Replacement, Back Panel: 1 단계, 이미지 1/1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Screen/Digitizer Replacement, Battery: 2 단계, 이미지 1/1
    • This step will require soldering. If you are unfamiliar with soldering then we recommend that you get help from another person or use the soldering guide made by Ifixit to help.
    • Solder the connections off for the battery.
  3. Trio Stealth-10 Screen/Digitizer Replacement: 3 단계, 이미지 1/2 Trio Stealth-10 Screen/Digitizer Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
    • Pull the cable away and clear from under the battery to avoid damage to the connection.
  4. Trio Stealth-10 Screen/Digitizer Replacement: 4 단계, 이미지 1/1
    • Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
  5. Trio Stealth-10 Screen/Digitizer Replacement, Speaker: 5 단계, 이미지 1/1
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  6. Trio Stealth-10 Screen/Digitizer Replacement: 6 단계, 이미지 1/1
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
  7. Trio Stealth-10 Screen/Digitizer Replacement, Front-Facing/ Rear-Facing Camera: 7 단계, 이미지 1/1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  8. Trio Stealth-10 Screen/Digitizer Replacement: 8 단계, 이미지 1/1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  9. Trio Stealth-10 Screen/Digitizer Replacement: 9 단계, 이미지 1/1
    • Remove the first layer of tape above camera cable connection slowly.
  10. Trio Stealth-10 Screen/Digitizer Replacement: 10 단계, 이미지 1/1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
  11. Trio Stealth-10 Screen/Digitizer Replacement, Motherboard: 11 단계, 이미지 1/1
    • Use your spudger to disconnect the screen/digitizer connection from the motherboard.
  12. Trio Stealth-10 Screen/Digitizer Replacement: 12 단계, 이미지 1/2 Trio Stealth-10 Screen/Digitizer Replacement: 12 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to grasp the screen/digitizer connection gently and remove each accordingly.
  13. Trio Stealth-10 Screen/Digitizer Replacement: 13 단계, 이미지 1/1
    • Grasp the EDC tape with your tweezers and lift it off gently from the motherboard and set aside to be reused.
  14. Trio Stealth-10 Screen/Digitizer Replacement: 14 단계, 이미지 1/2 Trio Stealth-10 Screen/Digitizer Replacement: 14 단계, 이미지 2/2
    • Use a Phillips #0 to unscrew the 4mm screws from the motherboard fixture.
  15. Trio Stealth-10 Screen/Digitizer Replacement: 15 단계, 이미지 1/1
    • Be sure that all the connections to the motherboard are disconnected. Proceed to remove the motherboard by slowly tilting it away from you and then lifting it straight up.
  16. Trio Stealth-10 Screen/Digitizer Replacement, Screen/Digitizer: 16 단계, 이미지 1/1
    • Remove all disconnected components and remove screen/digitizer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Daniel Coleman
회원 가입일: 10/29/15
643 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015 회원
UMASSD-MILES-F15S1G4
3 회원들
안내서 12개 작성하였습니다
댓글 2개
I can fix them like its no $@$* I want every tool to fixs them I use tool but I want the right ones I like making $$$$$
bkress81 - 답글
I want all smart TV that are broke I like working on them I have for many years
bkress81 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 3,086
