소개
If the speaker on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
필요한 것
To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
