주요 콘텐츠로 건너뛰기
Trio Stealth-10 Speaker Replacement
필요한 것
  1. Trio Stealth-10 Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Speaker Replacement, Speaker: 2 단계, 이미지 1/1
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Speaker Replacement: 3 단계, 이미지 1/1
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Coleman
회원 가입일: 10/29/15
643 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015 회원
UMASSD-MILES-F15S1G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 285
