주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force P11 Microphone Replacement
필요한 것
  1. Turtle Beach Ear Force P11 Microphone Replacement, Microphone: 1 단계, 이미지 1개 중 1개
    • Remove the microphone cover by unscrewing the screw on the front side of the microphone.
    • It is recommended to use #000 Philips head screwdriver.
  2. Turtle Beach Ear Force P11 Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Use a nylon or metal spudger set to lift out the microphone.
    • Be careful lest you might break the fragile wires.
    • Always try using a plastic tool before resorting to a metal tool as shown in the picture.
  3. Turtle Beach Ear Force P11 Microphone Replacement: 3 단계, 이미지 1개 중 1개
    • De-solder the microphone wires and remove the microphone.
    • Use low heat for de - soldering
    • Do not cut the white and black wires soldered to the microphone as you might reduce the length of wire required to reassemble.
  4. Turtle Beach Ear Force P11 Microphone Replacement: 4 단계, 이미지 1개 중 1개
    • Solder the new microphone wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • You can find more information on How to Solder here: 연결부 납땜 및 납제거 방법
    • To complete reassembly replace the cover taken off in step 1.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bhavesh Gandhi
회원 가입일: 09/26/15
585 평판
안내서 3개를 작성함
IUPUI, Team 1-2, Wilson Fall 2015 IUPUI, Team 1-2, Wilson Fall 2015 회원
IUPUI-WILSON-F15S1G2
2 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 2,072
