주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force P11 Speakers Replacement
필요한 것
  1. Turtle Beach Ear Force P11 Speakers Replacement, Ear Cushion: 1 단계, 이미지 1개 중 1개
    • Pinch the inner edge of the ear cushion from the bottom.
  2. Turtle Beach Ear Force P11 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Now slowly pull down the ear cushion as it completely separates from the speaker.
    • Carry out the pulling down action as slowly as possible or you might risk tearing the ear cushion otherwise
  3. Turtle Beach Ear Force P11 Speakers Replacement, Speakers: 3 단계, 이미지 1개 중 1개
    • Remove the 4 screws on the red speaker cover.
    • It is recommended to use a #000 Philips Screw Driver
  4. Turtle Beach Ear Force P11 Speakers Replacement: 4 단계, 이미지 2개 중 1개 Turtle Beach Ear Force P11 Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • Inspect the wires for damage as illustrated
  5. Turtle Beach Ear Force P11 Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • De-solder the speaker wires and remove the speaker.
    • Use low heat for de - soldering
  6. Turtle Beach Ear Force P11 Speakers Replacement: 6 단계, 이미지 1개 중 1개
    • Solder the new speaker wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • In case you use a large amount of solder, use a solder wick to absorb the excess solder.
    • You can find more information on "How To Solder" here:연결부 납땜 및 납제거 방법
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bhavesh Gandhi
회원 가입일: 09/26/15
597 평판
안내서 3개를 작성함
IUPUI, Team 1-2, Wilson Fall 2015 IUPUI, Team 1-2, Wilson Fall 2015 회원
IUPUI-WILSON-F15S1G2
2 회원들
안내서 6개를 작성함
6가이드 댓글
can you fix mine contact me a jtrent238@outlook.com
jtrent238 - 답글
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Bhavesh Gandhi - 답글
If you look at step four you will see the black wire has a knot and a silver metal part. Well My wire has broken right there any advice? Please help!
Dev - 답글
Do you know where I can get the speakers from?
James Patrick - 답글
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
John - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 4,006
