주요 콘텐츠로 건너뛰기
Turtle Beach Ear Force X12 Microphone Replacement
필요한 것
  1. Turtle Beach Ear Force X12 Microphone Replacement, Ear Pads: 1 단계, 이미지 1개 중 1개
    • Start by removing the left ear pad.
    • Gently pull on the pad from the side by the leathery material until it comes loose from slot.
    • Be careful not to rip the fabric.
  2. Turtle Beach Ear Force X12 Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Grip ear cushion and carefully pull up and separate from the plastic headphone.
  3. Turtle Beach Ear Force X12 Microphone Replacement: 3 단계, 이미지 2개 중 1개 Turtle Beach Ear Force X12 Microphone Replacement: 3 단계, 이미지 2개 중 2개
    • Your headset should look like the first picture, with the left cushion removed.
    • Repeat these steps for right cushion.
    • You may now continue with more complex inner headset repair, or replace the ear pads by sliding on new ones in the slot.
  4. Turtle Beach Ear Force X12 Microphone Replacement, Microphone: 4 단계, 이미지 2개 중 1개 Turtle Beach Ear Force X12 Microphone Replacement, Microphone: 4 단계, 이미지 2개 중 2개
    • Remove the three 1.1 mm screws around the speaker using a T3 screwdriver.
    • Open the top panel carefully.
    • Potential for device damage: The wires are very delicate and can be broken easily.
  5. Turtle Beach Ear Force X12 Microphone Replacement: 5 단계, 이미지 2개 중 1개 Turtle Beach Ear Force X12 Microphone Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 5 mm screw using a Phillips #00 screwdriver.
    • Carefully pull the wire to the side to allow access to the screw if necessary.
  6. Turtle Beach Ear Force X12 Microphone Replacement: 6 단계, 이미지 2개 중 1개 Turtle Beach Ear Force X12 Microphone Replacement: 6 단계, 이미지 2개 중 2개
    • Cut the microphone wire with wire cutters.
    • Desolder the microphone wires.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  7. Turtle Beach Ear Force X12 Microphone Replacement: 7 단계, 이미지 2개 중 1개 Turtle Beach Ear Force X12 Microphone Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the new microphone and solder the wires into the correct positions.
    • Position the speaker on the headset so the screw holes are aligned.
결론
작성자
7다른 기여자 명과 함께
Maria Fontiveros
회원 가입일: 10/02/17
101 평판
안내서 1개를 작성함
USF Tampa, Team S1-G3, Thompson Fall 2017 USF Tampa, Team S1-G3, Thompson Fall 2017 회원
USFT-THOMPSON-F17S1G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 2,083
