주요 콘텐츠로 건너뛰기
Turtle Beach Elite 800 Audio Board Replacement
필요한 것
  1. Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: 1 단계, 이미지 2개 중 1개 Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: 1 단계, 이미지 2개 중 2개
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Audio Board Replacement, Audio Board: 2 단계, 이미지 2개 중 1개 Turtle Beach Elite 800 Audio Board Replacement, Audio Board: 2 단계, 이미지 2개 중 2개
    • Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
  3. Turtle Beach Elite 800 Audio Board Replacement: 3 단계, 이미지 2개 중 1개 Turtle Beach Elite 800 Audio Board Replacement: 3 단계, 이미지 2개 중 2개
    • If you are working on the LEFT side ear, you will first have to detach the battery by gently unplugging the white plug on the top of the board.
    • Make sure when unplugging the battery to not pull the manilla colored part which is attached to the board, but the white plug instead.
    • If you are working on the RIGHT side ear, you will first have to remove the charging contacts (2 7.92 mm Phillips screws).
  4. Turtle Beach Elite 800 Audio Board Replacement: 4 단계, 이미지 3개 중 1개 Turtle Beach Elite 800 Audio Board Replacement: 4 단계, 이미지 3개 중 2개 Turtle Beach Elite 800 Audio Board Replacement: 4 단계, 이미지 3개 중 3개
    • Desolder the necessary wires. (Each side will be slightly different.)
    • Be careful when using a soldering iron. Refer to the desoldering guide for tips.
    • For the purpose of this guide we clipped the wires connected to the board.
    • Remove the 4 screws (7.71mm Phillips head) using the #0 screw bit, that are holding the board in place.
    • Finally, remove the audio board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Johnny Lofton
회원 가입일: 01/18/17
861 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 2,155
