필요한 것
To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 55개
So there are two batteries in this headset that need to be replaced?
Doug Green - 답글
Also, what battery do I purchase and does anyone know a good source to purchase them?
Doug Green - 답글
Max battery size: 50x36x9mm
Origina battery: 40x30x8mm
The pcm board can be replacement by old battery module.
Only one battery inside. Not sure why this guide takes appart the whole headset.
All steps&pictures related to right side (step 1, 2 and 4) are misleading and unnecessary when doing just battery replacement.
I ordered replacement on aliexpress.
What part number please and thank you in advance
